should be on the forum in one of the kyb threads, but the ones i remember was welding a tab on the steering head (like the yz have) and the other was door-stop rubbers screwed into the bike frame where the tubes come in contact, and the last being what you mentioned and what i had
I screwed then welded blocks onto the YZ triple lower, was pretty easy and clean and fit for purpose. Search my pictures should find it.
Ahh, here we go, post 43. There is weld a bit underneath but they butt up against the edge so they cant go anywhere. Several years on.
http://www.gasgasrider.org/forum/showthread.php?t=17744&highlight=Bearings&page=5
Yeah I wanted as much flat area to hit at the same time to spread the load.
Really I thought it was common upper, just certain through bike shop for not much.
A mate is local KTech technician, they have a cross country valving setup and it's been hardly worth a click here or there, it just works for me in either choppy or tree roots or just giving my arms an easy time which was getting to be an issue for me.
When I put the yz450f front end on my 2000, I needed to change one bearing. As I recall it was a pretty common wheel bearing and I bought it at the auto parts store. I am sorry I do not recall the number.
