Ok long story , my ec300 is overheating Bad! It has been a steady progression to this point. My jetting is 42/178 with a New carb w/ RB mods.I usually ride from 2000ft-6000ft at 60deg-90deg weather. My bike idles well and starts cold with no more then a couple kicks and warm with one. It always has burped up a little water and stopped once it get about a 1/8" above the fins. But on my last two rides things have changed.2 weeks ago after a steady but steep climb my bike overheated and half emptied my radiator. I waited tell it cooled and refilled the rad. I didnt have any problems after that. Now the ride I went on Sunday was a worse . Granted most of the riding was higher elevation and at 94 deg temps. And mostly hard work climbs (epic stuff). But my bike was constantly pukeing water . I gave it constant cool down times and at one point there was a long section of dirt road to the next trail . It even over heated on this. So I refilled and headed for the truck . Over heating and refilling all the way. I got home and pulled the impeller cover and the impeller was in good working order .
I am at a bit of a loss with this . If it was my jetting I would think the over heating would be evident day one. Not a slow progression to this point. I also want to add that it seams to be pumping the water out more then boiling it out. If that make sense . Pumps water out and gets hotter the lower the water level gets. I also noticed with the engine cold the water bubbles ,Faster or slower to engine speed.
I also have two other questions.
1. What happens when the water impeller seal lets go.
2. Can the head gasket leak enough to introduce pressure to the water system but not effect power and make white smoke?(wouldn't there be a fuel or some kind of odd smell to the water?)
Any help or suggestions would be appreciated . Even simple obvious stuff.
