I just bought an 04 GG FSE 450 Supermoto yesterday from a guy who claims the bike has 580 miles on it. It serioulsy looks like he isnt lying until I get it home and ride it around.
As soon as I started riding the speedo was working only for a couple seconds and then not reading anymore. It would read like 15mph for a split second and then go to 0 for the next 15 minutes. Then I checked the odometer and it said that it still had 582 miles after 10 miles of riding. I IMMEDIATELY said some choice words thinking I just got screwed on the deal and the bike had tons of miles but the speedo isnt working.
After inspecting the bike more closely I really dont think it has over 580 miles on it but who REALLY knows.
I was kindof pissed about that because (though the bike is in perfect condition) i hate knowing that there is a possibility i just bought a bike with more milage than it reads which really pisses me off.
TO GET TO THE POINT:
I began to inspect the wires and everything to do with the speedo and odometer.
I noticed the sensor on the end of the speedo cable when passing by the magnet on the rotor was quite far away and figured it might not be reading correctly.. I attempted to loosen the nut that holds it tight to the bracket and the piece fell off in my hands. (I was trying to see if the sensor just was too far away to give me a speed reading) It was broken. I am assuming this is the problem but under further inspection im not sure this is the only problem.
I took out my manual for the bike and it said to scroll through the different modes on the speedo which were labled by the manual as:
1. Speedometer
2. Speed
3. Total Distance
4. Trip Distance
What is the difference between the speedometer and speed? ITS THE SAME F***** thing? My speed reads zero no matter how fast I ride and the milage does not increase no matter how far I go. I cannot find out why this is happening. I dont know if its the sensors, or the speedo itself. I checked all the connections and they are all fine except for the broken part I discovered when trying to adjust it. Im not sure if this is the problem or not. The piece was not completely destroyed. When it broke it exposed the little wire node that gives the reading that is normally inside the threaded and covered piece. I was able to re mount it but it no longer gave any reading.
The reason I dont just think it this problem is caused by the broken part is that my speedo reads nothing like it says in the manual. The modes arent the same and dont do what they are supposed to do.
Mine reads like this as i scroll through the modes:
1.) 12:45 (Current Time of day)
2.) 582 (Total Milage does not increase)
3.) 0.0 (I dont know. Doesnt do anything Maybe trip meter but of course it doesnt work if the speedo cable is broken.)
4.) |- 0 (speedometer which doesnt work)
Thats what my bike reads.
The manual says ,"The initial display is the clock. (time) if you press mode the display goes through the 4 other displays" and then lists the options i listed before. So really it is saying it has a clock and 4 other options (speed, speedometer, total miles, and trip meter)
I am super worried because I want my bike to reflect the actual milage and i want to figure out if this guy is trying to pull one over on me by tampering with the odometer so it would read less miles than it actually has.
I just need help figuring this whole situation all out. I need to know how to work the tach on my bike and the manual is weird and doesnt make sense. How is speed and speedometer a different thing? I have a clock and a speedometer a trip meter and and odometer.
I am also going to try and replace the battery tomorrow and get another cable or sensor. If this doesnt fix the problem is there any other thing that anybody knows about that happens to these speedos?
I dont know if anybody has had any problems with these or has any knowledge of what I can do about it but I really need help. I need to figure out if this bike has been tampered with or if it is just some sort of defect or possibly and hopefully just operator error. The guy claims that it wasnt broken when he had it but who knows. I dont know the guy so really his credability is not worth anything to me because i dont know him. That is why im suspicous.
One last thing that also made me suspicious. The cable that runs from the speedo unit to the break caliper bracket has 2 crimped on connector pieces for (positive negative im assuiming) so you could disconnect or connect them if you want to. Are there supposed to be on that cable or did this guy clip them so he could pull those off when he rode so when he sold the bike it would appear as if it had low miles?
Any recomendations on this would be greatly appreciated. My eyes tell me that even if the bike was ridden it would be impossible for anybody to clean it up this good. There is no wear. Original everything. I am pretty sure this is just a weird coinsidence that this happened to the bike the day i bought it but still in the back of my mind is that worry and suspiscion that im getting screwed over.
Please help!!!
1. Speedometer
2. Speed
3. Total Distance
4. Trip Distance
Please help!!!
