I have the bike all set up (complete with Trail Tech Endurance computer whose pickup doesn't match the arc of the magna-bolt).
Anyway, I decided to check the sag.
With the forks level in the top clamp. Me at 190 and a 25-pound weight to represent full gear. I believe I have stock springs front and rear (the original owner was thirty pounds lighter and a mid-pack B rider. I'm a slow-C).
The insignia on the shock spring is a yellow Ohlins with "00596 10/52 L 264" written on it.
Static sag is 41.3mm. Race sag is 124mm (oops). I had loosened the spring earlier when I removed it, so this is not the setting at which I was actually riding.
I've heard some say that Gassers do well with higher static and race sag (approaching 30+ and 110+ respectively if I recall correctly).
What's a good setting for a rocky single-track rider who is afraid of speed? I'd be open to raising the forks up in the clamps if I use bigger sag numbers.
Thanks,
Rick
Thanks,
Rick
