The wheels are sold.
For future reference, the hubs are exactly the same through all the years, however there has been a bearing change to accomodate a larger axle on the newer bikes. The older bikes use a 6004 bearing on the front wheel, and the rear, with the addition of a 6005 on the outer in the rear. The newer bikes use 6904 on the front and rear with a 6905 on the outer.
It's a bearing swap away. Don't forget the spacers, if you're going from older to newer, the axle won't fit through the spacer, but you don't need it anyway!
