N nato New member Jul 15, 2013 #1 I had a quick search but cant find the thread on making the rear side panels tight! mine are starting to get a bit loose so what have others done?
G GasTimppa New member Jul 15, 2013 #2 nato said: I had a quick search but cant find the thread on making the rear side panels tight! mine are starting to get a bit loose so what have others done? Click to expand... I drilled hole in to middle of that clip wich gets to subframe. drill it as near sidepanels side as you can. Then zip tie it to subframes hole from inside of panel.Thats what I've done.
