GMP
Active member
The '12 shock comes out the bottom easy!
Remove pipe, rear wheel
Remove right number plate and rear silencer bolt, and pivot silencer up in rear
Remove rear pull rod bolt, lower shock bolt, pivot rocker back
Lift and retain swing arm all the way up wit tie down over rear fender
Remove upper shock bolt
Lower shock and turn so that reservoir is in left forward corner of swing arm
Tilt slightly rearward and draw out through bottom
