13 plastics on a 12?
wence
Bronze Level Site Supporter
G'day,
Just wondering how much better the 13 radiator shrouds are compared to the 12?
Do the 13 plastics fit the 12's?
I read that John rb said they did not?
Any more info?
I am in need of some radiator shrouds and was thinking of getting a whole new 13 plastic kit.
Cheers Mark
They fit, may need a little trimming on the back to clear some rad frames but most shrouds do anyway.
Ok,
I just managed to comletely separate the right side shroud and break both tags whilst checking out a tree on the weekend. So I would need top and bottom .
Cheers Mark
I've spoken with GG UK & they're sending me L&R lower rad shrouds & the fittings to attach, will let you all know how it works out.
I have actually avoided having to purchase just at the moment as I have drilled a hole in the lower plastic where it lines up with the hole on the Scorpion guard.
The rad guard and brace has a rod running across the rad. I undid this 6mm bolt and replaced it with a longer one that runs through the plastic , plastic spacers and then into the rod and guard.
All good so far.
Cheers Mark:D
