Put together my 2000 XC300 basket case.
Got it started easy enough. It ran very well for about an hour and a half ride time.
It then became very hard to start and when it was running it was breaking up a bit at mid range rpm. Now will not start at all.
First thing I did was check for spark and I have none.
Coil I suspect? took my kill switch out of the mix all together, its not that.
I sanded the fresh powder coat off both mounting points of the coil to bare metal. Also sanded the voltage regulator ground mount to bare just behind the headstock.
Is there any test I can do with a multimeter to test CDI? coil resistence? stator?
Where should I start and where can I get replacement parts?
