Tried searching through the threads, but struugling to find what i need..
Bought this recently, and it runs, but rough enough.
Here's the jetting..
needle : NIED position 3
Pilot: 45
Main jet: 185
It starts first kick and idles well, but stutters a good bit getting to the top end and doesnt cruise well.. I also couldnt tell if the powervalve is working or not, as in there's no great pull at any stage..
I changed the needle to position 2 and this seemed to smooth it out a bit but again not sure if the powervalve is kicking in.
I've also bought a 180 main to see if this will help.
So, a couple of questions! Should i raise the needle position another notch and put the clip in position number one?
I'm also wondering is it even the right needle, and would i be better changing to a different needle?
Cheers in advance lads, haven't owned a 2 stroker in a good few years, so taking a while to get to grips with it!
Pilot: 45
Main jet: 185
