I have had alot of problems with the clutch on my MC dragging and not disengaging.
But since I also have a EC and it is much better for enduro riding and thats what I do most, I just let the MC sit in the garage unused.
But this weekend I have a enduro on a fast track with lot's of whoops, and the MC's crazy fast engine and 50mm fork and stiffer rear suspension is alot better for that track than the EC, it'll just bottom out on the first two whoops and send me flying
So, since the EC's clutch was working really good with no drag at all, it was going to be a easy fix, just swap the complete assembly from the EC to the MC
But when testing, the clutch was still dragging and acting wierd
I had to adjust the stroke on the lever to get it to disengage, and it would only disengage when pulled all the way to the handle, and it was still dragging bad..
When I removed the slave I noticed that the piston was futher out than when I installed it??
Pulled the clutch rod on both EC and MC, and found that the rod from the MC was 3mm shorter than on the EC
Put the long rod in the MC, and no more problems....
They are both 2006 bikes and have same part number on the clutch rod??
Must be a production fault, I can't belive the tolerance is +-3mm for that part..
Just wanted to post this, since some of you have similar problems with your bikes..
