Caravan Monster
Can anyone help me find a 3 letter Keihin code for this needle, or it's nearest equivalent (even another OEM bike manufacturer equivalent code would be helpful). It is marked NB*HW (the 'B' looks like an upside down greek beta). The carb is PWK 38, screw top, four vent
I have the table for the N427-48 needles. To generate the Keihin code, we need Taper (degrees) | L1 (mm) (top clip to end of first taper?) | straight section diameter (mm)
I'm getting 2.84mm for the straight section diameter, but can't find a distinct end of the first taper for the L1 measurement, and have no idea how to measure the angle of the taper (which taper anyway ? - I think there are 2, if not 3 different tapers on this needle.
The objective is to lean out fuelling in the half throttle region. Small and wide open throttle is good. I suspect the standard needle may be worn, so aim to replace with an equivalent, and also try a needle that is a touch leaner in the middle. Mechanically, everything is good, ring gaps well within spec, 1.5mm squish, pv adjustment done, 50:1 fully synth mixture.
It's a tricky problem to resolve because the UK Keihin importer only deals in 3 letter code needles, and GGUK seem to have stopped answering the phone, so any help would be much appreciated. I've found a couple of interesting things with this overhaul, including getting a strong tickover without winding the tickover screw right in
 and will write it up when the needle problem is resolved.
