yes what is it with the m3 screws?
Have been thinking about getting the fork caps drilled and tapped to the same dimension as the jap bike bleeders, will be easier to use a flat screwdriver and then i can also use my air-cells on the forks to soften up the small bumps
I'll be happy with something like these, so at least it wont require tools to bleed the forks.
http://www.shear-loc.com/m3thumbscrew.htm
bought some Zeta air bleeders (red) & fitted them last weekend,drill & tapped.Easy to do & sit neatly in front of the bars well protected.Will try them out this weekend & see how they work.
I will be taking my fork caps in to get drilled and tapped, any pitfalls i should know about before i remove them, have heard about little balls falling into the forks etc or is it just a matter of loosening the tripple clamps and taking a spanner to the caps?
help is much appreciated
moto9 very helpfull info. I plan on getting a drill and tap set to add bleeders to mine. I moved my bars forward yesterday and now I can't even get to the clicker screws. Any suggestion on this or should I just move them back?
You can make up a fancy tool like the one RaceTech sells (large diameter washer essentially with a mini screwdriver blade sticking out of one side) or bend up a piece of steel into a tiny hockey-stick shape to get to the clickers
thanks guys. I also have my bars set forward, but since i am not a suspension expert and all the articles i have read by suspension experts seemed to indicate that unless you know what you are doing it is best to leave the rebound in the standard position.
That said, it would be nice if th ebike manual actually said what the standard setting was!
