nick790 New member May 10, 2010 #1 Is this right? can also get a 5.5? Your thoughts please? Also, where do you get your spring from for your sachs shock? Here in the UK, it seems impossible. Can you fit a ohlins or showa spring?
stainlesscycle Site Sponsor May 10, 2010 #2 ohlins spring should fit i would think (i have a 5.4 sachs shock on my ohlins..) i'm 200lb in gear and 5.4 is perfect.
P pedroec300 New member May 11, 2010 #3 nick790 said: Is this right? can also get a 5.5? Your thoughts please? Also, where do you get your spring from for your sachs shock? Here in the UK, it seems impossible. Can you fit a ohlins or showa spring? Click to expand... You would probably need a 5.6 at that weight,i have this spring in my 07 300 with .46 fork springs. I am about the same weight as you. By the way i am fairly sure a kyb spring will fit your sachs shock.
