Short of just starting over with a JD jet kit...which is prolly where I will have to go.
The bike will idle ok then all of a sudden just hiccup. If the idle is down when doing this it will die with a loud clank. If you stab the throttle off idle it will die. once you get past that it runs ok up top.
What do you guys think?
Even after typing I am thinking JD jet kit.
