F forgiven New member Dec 4, 2013 #1 I was looking at replacing the stock throttle cable. Would there be a problem with getting a WR250f throttle cam assembly and WR250f cable or can I just use a WR250f cable and be done? Thanks
Jakobi Super Moderator Dec 5, 2013 #2 The throttle is probably the same setup. If in doubt open it up and have a look. Should be a basic 2 cable push pull setup. In saying that, if you have a plastic throttle tube, upgrading to an alloy one would be my choice.
F forgiven New member Dec 5, 2013 #3 Looks like a standard push pull FCR. Just never know about those crazy Spaniards though. I think I will go with the moose YZ version and get a control cam for it. Should be a nice upgrade anyway. She will probably only notice the new grip.
