48 cc marzochi revalve help
rvktm
Got round to to fitting the 01 ics springs think the originals are 1.6 what oil do I use got maxima light and medium? Shock oil for the cartridge .putoline 5or 2.5 outer .thinking of soferning the comp low speed stack ?
Outer fluid doesn't do much more than lubricate the seal lip and bushings. Viscosity is of no real concern.
From what I recall the OEM fluid is Marzocchi 7.5wt. This oil is rated at 26.1 cSt@40C/5.25 cSt@100C/VI 150.
I always used the same oil I always use in everything which is 15.9 Viscosity @ 40?C, cSt, and 4.4@100... VI 209.
I used Maxima 85-150 5wt at 220cc inner and 300cc outer. It's 16.2 cSt@40C/4.4cSt@100C/VI 201. I've had this same oil in all the Showa and KYB forks I've run for years. I love the action of my 48 Zokes forks with this oil.
That said, cartridge and outer chamber fluid should be the same as the Zoke 48's are a semi-sealed cartridge fork.
My forks are good everywhere. Rocks, square edges, whoops, etc. If it helps, here is my compression stack:
Bolt
Spring
31.85 x .3
Base
11 x .3
11 x .3
18 x .1
20 x .1
24 x .1
13.8 x .1
31.8 x .15
31.8 x .15
28 x .1
2.5 spacer
attachment.php
Thanks boys with the shims I had from ics piston 28/01 12/01 32/1.5 22/01 32/1.5 then std set up 26/1.5 24/01 22/01 20/10 18/1.5 2x 11 /020 used maxima shock oil did a mix of 18 centy strokes didn't touch the rebound ?
Did you test it yet? How does it feel? I presume you might want to increase the rebound somewhat. Many of us have experienced the need for one more shim in the rebound stack after going to lighter than standard oil.
thanks all for help road sunday mix of flat out stubbel fields bit of woodland . much better set ppf 1 1/2 comp at 22 rb 14 . the ttx rear has to much ls comp for me got it set at 22 out gg say 10 to 14 another thing to do. iv got ohlins charts do that six different piston shim settings !!!!!!!! .only thing on the forks is there not a lot of sag its on the std clip ? but overall a different bike reminds me of my 81 490 maico
