Would I only need clamps and forks from a 99, or would I also need the front wheel from the 99?
Anyone remember if the rake/trail was the same with the conventional WPs, and also fork length? I tried this with an 02 KTM 520 exc, and it was alot harder than it looked. The KTMs used 50mm WPs until 99, then went to WP USDs, so I thought it would be an easy swap. Nope. The 50mm clamps had a substantially different offset, the forks were either longer or shorter, don't remember, and the front wheel used different spacers. I think I also couldn't use my front brake caliper from the 02, or maybe it was the disc. Maybe both.
Hopefully GG made it easier? If this an easy swap on my XC I want to do it.
I have forks and front wheel from an 04 CRF 250, (Showa), on my GG now. I have never liked the WP USD forks. They have too much stiction and are unpredictable. And fork seals blow often. I was constantly cleaning seals on my 02 KTM, sometimes both forks, and before each ride I was trying to get them to reseal.
