'98 flywheel
Marki
Hi again.
Does anyone know the size of the flywheel puller that I need for a 1998 EC250?
A quick measure shows it as 27mm x 1mm and what looks like it might be a left hand thread. Does this sound right? Just want to check as I've been told that there are various types for various years.
i wished i could tell you for sure... i have a yamaha flywheel puller which is 27 mm and i know years ago i used it to pull the flywheel off the 2000 i had..
it fit a yz400f and has 2 different sizes on it...
i have never seen the fw on the early bikes...
someone will know for sure..
It should be the same size as all the Kokusan 2stroke ignition flywheels, 2K-2s and 2K-3s, used on the GGs, KTMs, Kawasakis, and others. All flywheel threads for the puller are left hand threads. I think that the '98 is just a 2K-2 with the Ducati Energia rotor on it, correct?
Thanks guys.
I measured it myself and it is 27mm x 1mm left hand thread.
What had confused me was a few places selling pullers for Gas gas with a right hand thread.
