I bought a 99 ec200 for cheap in great shape. love it. Marzocchi conventional forks
1. The front brake started to drag, wouldn't release well. The pistons were sticking so I thought that I would put new seals and wipers into the caliper. Well the seals and wipers appear to be too small in diameter. I thought that maybe it will all stretch when you put it together. I lubed everything up well and tried to push the piston into the caliper with the new seals. When doing this I took a chunk/bite out of the dust wiper. Sheared it off between the caliper and piston. Back in the house to order new parts. Is it supposed to be this way?
2. When back out to replace rear brake pads. The new pads don't fit. The package says '97-'99 ec200 but they are not the same. The new pads aren't long enough and the tab that locks into the rear caliper is not large enough as well.
So, now I think that I may have different brakes on this bike. There seems to be different parts from 2000 up. Is it possible that there was a mid year change and I have the 2000 parts on my bike? Does anyone know the piston diameter in the caliper of the various years so I can compare?
