I'm doing the top end in my 300 (its first one), and I've taken some numbers down in order to decide how I want to adjust the squish. I'm planning on putting in a shorter base gasket stack, but I want to get some advice from you guys to make sure I don't get the compression too high or throw the port timing off too much. Here's the measurements I've gotten from the stock setup:
squish, about 2.3 mm
trapped volume, about 26.3mm
computed UCCR, 12.1:1
deck height, -4.45mm (I used digital calipers as a depth gauge, so this is not very accurate)
squish band offset from head surface, 2.40mm (just for reference)
I have 2x green base gaskets, and one grey. I've measured the thickness at 1.3mm.
Q: Are the numbers on the "measuring the squish" page from JB correct? Green is .3mm and grey is .5mm? That would give me a 1.10mm stack, which doesn't measure out. But if green is .3 and grey is .5, then that matches what I've measured.
At BDC the piston is even with the bottom of the exhaust port.
On reassembly I'm thinking of putting in a single .50mm base gasket. That'll give a squish of about 1.5 - 1.6mm, which sounds like a good target. However, it will lower the ports so that the piston will be 0.8mm above the exhaust port at BDC. That should give some improvements to the bottom end, but I'm wondering if .8mm is too much? I'm fine with sacrificing some top end, but I don't want to go overboard.
I currently have a .3, .38 and .5mm cometic base gaskets on the bench.
I have a lathe, and could cut the cylinder head, but 1) I'm not a professional and 2) it's a mini lathe and not all that rigid so I'd be concerned about the interrupted cuts over the cooling ports.
As to the change to the compression ratio: going from a 1.3mm stack to a .5mm stack = .8mm difference, which should result in a change to the trapped volume by about 3.3cc. So 26.3 - 3.3 = 23cc, which should put my UCCR at about 13.7:1. I'm running 98octane pump gas (or whatever is the highest available octane when getting fuel). Is 13.7:1 a tad high for pump gas, or should I be okay? I'm generally riding near sea level, low 40F in the winter to low 70's in the summer.
I know I can send the head off, but frankly I'm happy enough with the bike and I'm just looking to make improvements with what I have available.
Thanks in advance for your advice!
-Jesse
-Jesse
