I had a small knocking noise that was real prevalent at the clutch cover. So I pulled the engine. I needed to check my top end anyways. I think I found out were the knocking was coming from. The cerclip was missing at the front of the clutch basket. I checked the connecting rod end play and it is right at 1.00mm which is the end of the tolerance range. I am thinking I should split the cases and rebuild the bottom end. But I am broke and not liking the idea of spending $200+ on parts . On the other hand I wouldn't like to blow things apart because I didnt. What do all you smart people think?
