RockefellerGG
2005 EC250
3 parts are damaged and I need some advice on the path forward.
1. Crankshaft - Needs to be rebuilt. The needle bearing, and inner washers are in bad shape/destroyed. I can pull off the inner bearing ring and order the rod rebuild parts. I've seen companies like R-B Designs will rebuild the crank for $60. It looks like they get it balanced and run-out minimized. Is this necessary?
2. The cylinder has a good gouge in it. I'm not sure that it can be repaired. Sleeve it? Replate? The rest of the cylinder looks to be in good shape.
3. The head has some gouges too. Replace with a used head? Wait until the end of the rebuild and have it machined and do squish mods at the same time?
