airbox washing cover?
roostafish
Is there such a thing available for the '07 and newer bikes? I'm douching my air filter each time I wash my bike.
Don't trust those things. If you use one, stuff a rag in the boot behind it. My friend was careless with one and lost a motor from water getting past that he did not notice. It ran down the boot, through the carb, and into the lower end. I have some extra foam blocks I stuff in the holes between the seat and side panels, works fine in keeping excessive wash water off the filter. Most of the time though I swap the filter anyway after a ride.
what bike is it as you must be a bit careless to get the airfilter wet, comparing to my 08 450, you could try using Belray filter oil, even if it gets wet it does not matter as it repels the water, even if the filter got wet it cant get into the motor and would just evaporate.
