I have a 03 that starts great and runs great until the engine gets up to a normal operating temperature. That's when the problems start. I will then only idle for a short while then it dies. Comming down from higher rpms it will die, like when you a comming to a stop. Still runs good at higher speeds though. Always fires right back up when I hit the magic button but I'll have to keep the revs up to keep it from stalling out. It seems like it's starving for gas once it get warmed up at the lower rpms! This problem seems to be getting worst as time goes on. I pull the plug and the color looks as it should
The bike has a new starter relay, new battery. The connections to everything looks good and tight and clean.
What's puzzeling it really runs great until it's warmed up and starting has never been much of an issue with this bike.
Any suggestions on what else look for would be appreciated.
