Hi
I have a 2005 wild 450 HP which has had a replacement frame (A rubbish one) I took it out for a ride and decided that because of the low ground clearance on the frame its only fit for breaking.
I believe its the same engine as fitted to the bikes.
The engine wont wind over fast enough to fire although the starter doesnt stall out. I have tried a replacement starter and jump starting and its just the same. I dont have a kick start for the engine but it starts no problem with a bump.
I have read starting issues are common with these. Is the problem usually the clutch or is their another soloution?
It runs but not as well as it should it seems very rich. It has a techlusion TFI module but I have wound that back to the stock position and its still the same.
I imagine it has a sensor fault but the dash is missing and the wiring is a taped up mess so I do not know where to begin. Has anyone fitted a carb to a 450? Failing that does anyone have a wiring diagram or some pointers they can share?
I plan to use the suspension and brakes on my other quad but it seems a shame to see the engine go to waste since from what i read they are good going things.
Thanks for any advice
Scott
Scott
