can anyone help as im a bit confused!
I (stupidly now I think) decided to change the clutch fluid (mineral) I initially went to bleed it with gravity, the first thing that was strange was that the fluid didn't come out of the bleed nipple but came from underneath the braided line so I presumed maybe bleed nipple or something clogged up so took everything apart, cleared out and when using air can see that its getting through the bleed nipple fine, so I hooked everything back up with new washers and go to back bleed it and I cant get any fluid into the system at all at the slave cylinder? am I missing something completely obvious or maybe I should but a new piston in the slave cylinder but there were no signs of any problems before I started (wish I had just left it alone!)
