When we had the shop going, we tried to run a single .15 mm gasket, but had a lot of trouble getting it to seal. We/I don't like to put gasket sealer on the base gasket, but prefer to let the cylinder nut torque compress the gasket to achieve a good seal.
The .15 mm gasket is provided to work with one of the thicker gaskets to achieve desired compression and port height. The original 300 ('99) came from the factory with a .5 and a .15 stacked together.
On my '99, I ran a single .3 mm base gasket, but on my '06 I use a single .5 mm base gasket.
