Is the photo true to colour?the exhaust side always gets a little "stained",the inlet side will be way cleaner,looks ok to me.what octane fuel?
If you dont want to mess with your jetting but think you might be rich you could try mixing a tank at 40:1 and see if you notice any difference(better or worse).sounds wrong i know but when you add more oil you reduce the amount of fuel per litre,actually leaning the petrol mix a little,whats recommended on the h1r pack?you can check plug after a ride and see if its better,but you may/maynot also notice a small change in the way it runs.h1r has a very high flashpoint meaning it works best at full noise,max temp,if youre riding slower technical type stuff it just doesnt get hot enough to burn well leaving a film of unburnt oil(everything lightly oiled-how can that be a bad thing?),it keeps things in very good cond internally,your powervalve @20hrs will be a little oily(wet) thats all.a pic of your plug will give the jetting gurus something to work with if you want suggestions.(try and show down inside plug with light)you can get some idea of main jet,idle jet,heat range,ignition timing.otherwise post your jets,slide no.,needle,fuel mix,typical riding elevation and temp range,or trawl the jetting database for others to compare with keeping in mind youre looking for similar octane fuels and similar elevations to what you ride.some of the jetting sounds nuts until you realise theyre at 5000ft or running ethanol,etc.
if you have the choke lever on the bars,make sure its not coming on a little when you turn fully to either side
also if it had no fuel when it went to dealer,or they removed and emptied tank they may have mixed up a small amount or tipped in ?mix
how was the choke left on?ive had both the handlebar lever and carb button versions on mine and both require holding "on",maybe the cable is pinched under tank?
