BRP Top clamp
DLS
BRP Top clamp, for fat bars. Accepts Scotts damper. Will fit any GG with a 100mm X 40mm bolt pattern. (Also fits Yamaha). $50.00 plus shipping.
gasit16, it should fit those as long as your bolt pattern is 100 X 40, however, someone else has spoken for it. If that falls through for some reason, I'll let you know.
Sorry, I've been away for a few days and just now checked the board. If you'll get me your address, I'll mail it out to you. I'll put a note in the box with shipping cost and my info then just send me a check for $50.00 plus shipping.-Don
clamp
Did get your P/M- What city? I got the street and state but no city. It's got a zip so I guess it doesn't matter. If I get your info back tonight , I can send out tomorrow.
Gasit16, A thought just occured to me as I was boxing the clamp up. You had asked if it fit certain years of GGs and I said yes if your bolt pattern was 100x40. While this is true, are you currently using fat bars? This is a top clamp only which does accept the Scotts damper. It does not include the lowers. If you already have 1 1/8 inch bars, no problem. If you have stock 7/8 in. bars, it won't do you much good. I'll wait for your reply before mailing.
