adv rider
How are the cables/wires routed on 2012 to eliminate them from being used as a steering stop? Turning right goes right to stop, but going left used the clutch,throttle,wiring as a stop. That small amount made a difference in the switchbacks.
I separated the wires from the throttle, and clutch, but it only goes right to stop if I hold the cables up high toward gas tank. Do I need to zip tie these way up?
Also I read that some have used the Twinwalls without crossbar, how has this worked? No problems with the bars failing? and did you cut off the crossbar mounts?
