Carb jetting 200 EC
maclab56
I've tried to search thru most of the messages and only saw 3 post about Carb jetting on 200 EC's.
I currently live in the SE and it's single track / tight woods. it's a 2003 200 EC, has New packing in FMF Turbocore, new reeds, primary seal, JD jet kit and pre mix @ 50:1. It's still spits and drools all over the back fender.
How far down can I go on the main Jet? It's also been suggested to install a Lectron carb. as the 200-300's all use the same size carb, anyone have different jetting they use or carbs ???? Scott
My 05 is running a 172m which I'm going to change up, a 38 pilot and jd red needle.
If you type "ec200 jetting" into the search tool there are 50 results.
Paulos
Thanks for the search info. This site is a little different than some of the others I use and need to spend more time on it figuring it out. :)
200ec jetting
2011 200ec six day edition.
This is what I have right now just had the bike for a month and just started to play with it. It runs very good. I still think I need to go a little lower on the pilot jet but that was the smallest I had.
PWK 36mm
PJ #45
MJ # 175
Needle DEK 3rd clip
SLIDE # 6
AS 1.5
I ride from sea leavel to 500ft
Hey Scott -
Here's a thread from when I was trying to get my '11 EC200 sorted on jetting: http://www.gasgasrider.org/forum/showthread.php?t=16519
End result is I still have drool coming out of the pipe, but the response is spot-on and she performs well, so I deal with it.
I'd guess that I'm slightly higher in elevation than you in the SE, though that might not be the case.
One suggestion if you haven't done or considered is to get the head mod done. This made getting my wife's 200 sorted a ton easier and it also improves the fuel efficiency.
I was initially concerned about all the drool, but after lots of advice from Jakobi and others on here, I figured out that jetting for throttle response is way more important than worrying about the drool factor. Still a pia to clean up after a ride, but at least I'm smiling whilst cracking the throttle...lol.
Hi Scott
Ive just been tweaking my 200 (06) and have found this excellent, although Im over in the UK 500ft 10'
38 pilot 1.5 out on a/s
R1369n needle in middle
180 main
Runs sweet, the R13 taper has really given my mid a bit more punch
Cheers
Chris
02 EC200 jetting
I am really struggling to correctly jet my bike and I would appreciate a bit of help!
I'm in the uk and ride at 700ft above sea level. I have a keihin pwk 38 air striker carb I'm running a 38 pilot and a 165 main with a N1EF needle on the middle clip. The problem I have is evidence of rich running, a lot of smoke and bogging down. I've replaced the boyesen reeds with carbon reeds which improved my fuel usage massively but it still seems to be running too rich.
Any help would be appreciated
165 main seems lean to me,that needle will however be rich 1/4 -1/2.id guess when you putter about slower the bike is loading up with a rich needle then when you open up the lean main gets things hot and the excess burns off in a heap of smoke.i would try-bump the main up to a safer 175 first,then drop needle to clip2.
Altering the main will only affect 3/4 to wot.
For what it's worth I am in USA ride at 5000 to 8000 ft I am running 2011 200 sixdays carb done by rb design as1 squish set 178m 42p jd blue 4th from the top at 60 degrees runs perfect good plug color
Be careful when comparing to others jetting,different thickness needles use different corresponding jet sizes.if trawling the jetting database try and compare to an equivalent setup(same carbtype,needle,engine size,similar fuel) in similar operating conditions (elev,temp,humidity)
For eg there are some weird setups in there until you notice they run at 5000ft or on an ethanol blend!
Deano im suspecting someone has dropped the main size in an effort to eliminate rich cond caused by n1e?
the n1e?/noz? are notorious for a rich burbly bottom end,usually better in clip2 from top,but that 162 main is risky lean so bump it up first,then drop needle/raise clip to #2.
If you are still unsatisfied look at needle options
thanks for your advice so far, as you can probably tell im a bit of a novice when it comes to jetting. and like you say its hard to compare when the running conditions are so different.
i will take your advice yous have given me up to now and report back with my findings.
