Carberatour installation
Noobi06
Can someone send a picture how and where the hoses in the carb is supposed to hook up? Its like 500 of them. Where does fuel tank thing go and what is the rest of the hoses. I am ASS in carbs
Thanks in advance
:eek::eek::eek::eek::cool::cool::cool::cool::rolleyes::rolleyes::rolleyes:
You can do it like they come stock and run all of them down where they will suck up water and mud or you can fix the design problem as follows.
I run the vent hoses that exit the carb pointing up into the air box and the ones that come out horizontally get run down between the lower shock mount and the linkage dog bones. The float bowl drain gets run down too.
You may need to cut the black band that secures the hoses together so you can run them different directions.
With this modification, the carb can "breath" clean air from the air box even when the lower vent lines are under water.
But you need the special 'powerband' that holds the tubes in a nicely wrapped package!
A dealer I visited had them for sale in proper vacuum wrap. LOL might have been Jim Cook
