Jakobi
Embarked on a single track mission straight after work (14hrs of night shift). Home by 8:30 and on the bikes 9:45. Small group of riders of known calibre, with intent to spend a good couple solid hours working some single trail loops.
Crossed the first real creek. The base had been washed out over the wet season and its quite deep. All bikes made it across with exception for one which had a swim - ktm 450exc. We revived it, after pumping the water out of the exhaust and cylinder, however while idling away one mate managed to melt his pants onto the exhaust pipe. At the same time we noticed a flame under the fuel tank!! The tubing that vents from the head back around to the crank case had been making contact with the exhaust and with sustained idle and no airflow temps rose enough to burn a hole in it. We taped it up best we could and continued on.
Next stop, Obi had been losing oil from the breather and decided to pull the plug. Got home and lucky he left when he did for more than one reason.
We continued riding from flaggys track, into hells gate. A section of single which initially took 4 hours to ride half way while cutting it in - but can now be knocked out in 20-30mins keeping a good flow. No issues and the crew kept moving.
Went from there into ktm link, which is a short section of technical, but still virgin flagged single. Slow going for a few kms. Then onto Ktm track which has a few nice short climbs, and a few more rocks than earlier. Once again we're on par and moving well. Come out of there without too much drama.
Doubled back around to the northern end of flaggy and rode back in to the intersection of hells, and another freshly flagged single; Billy Goat Bluff. Its only 6km of single, but its got some quite difficult off camber climbs, knee high grass, and a load of ninja rocks and logs hiding under the ground cover. Bloody hard work later into a ride, but we were going well.. until we reached the rainforest.
Slippery rocks and roots, no traction, not much tread on the tyre, not much energy left, and what was had was sapped. The rainforest is only 300m, but I think I would have made it half way at best. The group of 5 split after losing around 2 hours struggling to climb a snotty section, to the point I could hardly stand up or walk. The camera man couldn't hold his phone to shoot a clear pic. People were swearing, engines labouring, and thoughts of never riding again were entering the minds. 3 perservered and made it through, while myself and another turned back.
