Chain tension
For my '14 the manual says to put the bike on the side stand and measure at the end of the chain guide, slack should be between 35 and 60 mm.
Run it where you feel comfortable.
Other option is that next time you have the shock out, pop the linkage back together and run the swingarm through its stroke and take note of where the chain is tightest. Mark and measure in a specific area for your own records and you'll know what works best.
I just stick 3 fingers between the swingarm and slider at the rear. I find my chain is usually a bit on the slacker side.
When its a bit slack you'll get a bit of chattering/chain slap when rolling on at small throttle openings in higher gears.. but I've never let that worry me. I'd rather be a bit loose than too tight.
