I have 08' EC 300 with only about 10-15 hours on it. I drowned it at the last race and pulled the cylinder off to check everything out and flush. Everything looked good 175 compression .585mm ring gap. I started the bike and there is horrible chatter when at idle. Soon as you give it gas it goes away. Riding, the chatter stays same tone when you let off but soon as gas the noise goes away.
Checked all mounts, play in crank/piston, clutch plates...
Any ideas??
Any ideas??
