Today I pulled the top end, and to my surprise: cylinder and piston are fine. I now discovered, that at least one main bearing is damaged. Crank has no side to side or up and down Play, but when you turn the motor over, you can feel the individual balls grinding in the bearing rings.
So that leads me to two questions:
1. How can new genuine brand main bearings of that size, be trash after 2 operating hours. Of yourse I was very gentle when instaling them. No hammering on the inner ring whatsoever
2. Why did the motor have no compression? Maybe the main seals were damaged also, and somehow that leads to no air that could be compressed getting in the cylinder?
I'm no engine expert by any means, so please help me out guys. Before rebuilding the damn thing again, I at least want to know, why it failed.
