I have an '11 300 6-days and had been playing around with low end jetting for a few weeks before I ran across this thread in the engine section:
http://www.gasgasrider.org/forum/showthread.php?t=9517
When I checked my powervalve freeplay there was noticeable slop. After performing the adjustment mentioned in the thread, the low end power delivery became much more predictable and my jetting adjustments converged to a reasonable solution.
I'd like to recommend that everyone check their powervalve before they start experimenting with jetting.
My final jetting set up is (38mm Airstriker II, sea level conditions):
170 Main
JD blue needle #2 clip position
45 pilot
Airscrew open 1.0 turns
It also helps to leave the ignition map switch in one setting while making jetting changes. I use the milder map setting for all my riding (rain setting). I measured 22 mpg fuel consumption with these settings in dry riding conditions (average ride speed 21 mph).
Steve
170 Main
45 pilot
Steve
