First of all... Hi, this is my first time to the world of GASGAS!
I have just purchased an 07 EC300 and the shizer forks have been revalved and resprung with .45's and it feels great.
The rear however blew at a desert race and a new shock has been supplied under warranty. So far I have set the sag to 3cm static which works out to total sag of approx. 105mm, perfect for my weight.
The problem i have is i cant find anywhere in the owners manual on where the clickers should be?
At the moment i have 5 clicks out on HS compression, 12 clicks out LS compression and about 8 clicks out on rebound.
I am using the bike for woods type events, can you guys advise what settings you are running on your shock so i can have a better starting point?
