John deere is a mixed signal on that front.. there is two lines.. the crap you buy at lowes/Home depot, which actually is the same as scotts, sabre, lawn boy, troy built, cub cadet and poulan and several others. and the good line that cost twice as much. You spend the $500-2500 on a low grade tractor and you get one,, no matter who makes it. John deere used to not be in that market. They bought most of the smaller companies and still produce them and now produce lower grade JD mowers for the lower price point also. Go see the $4-8k price range JD mowers, water-cooled multi cylinder, fuel inj, or diesel.. True hydrostatic drive with pto access front rear and center, and optional 4wd.. or just go get a good zero turn and you'll be happy. Just dont buy at a home improvement store..go to a equipment specialist..
