swazi_matt
Active member
i recently got a clutch cylinder cover to protect it from rocks. Now when i was installing it i did not realise that the assemply (near the sproket) is spring loaded and thought i could just remove the 3 bolts hold everything in place and place the cover on. unfortunately i was not expecting the assemply to spring out and some fluid leaked out before i could push it back.
What i would like to know is what should i do to bleed the system once i do install the cover ( am sure i have let air in and will let more in when i do put the cover on).
Anyone got a nice pictorial diy they can send me?
Also what fluid do i use for the bleeding?
should i look at getting a bid syringe and backbleeding?
thanks tech gurus!
thanks tech gurus!
