clutch issue
gasn4christ
so i had to replace my water pump seal as the coolant was getting into the tranny. pulled the clutch and inner cover.. made the swap of seals... put it back together and now...... my clutch does not disingauge.......... before i took it apart. it did drag a little. sometimes it would almost come to a stall at idle with the clutch pulled in gear. i bled it a couple times and it feels like it should just not disengauging..... anybody??? oh 2012 300ec
soooo im calling this one my bad...... the washer between the inner basket and clutch hub had fallen off the shaft when i put it back together..... im dumb...
