sneaky98gt
2011 EC250, with an AJP clutch master.
Are there any common clutch master cylinders out there that move the reservoir / cylinder away from the bars a bit?
I've got Flexx bars on my bike (which I really like), but because of how they're made, I can't slide the master cylinder inwards much before it binds up. See the picture below with the red arrow pointing to the interference I'm talking about.
This wasn't much of a problem until I cut 3/4" off each side to help with the woods riding I do. The clutch lever still clears the handguard, but now my hand / finger is 3/4" closer to the pivot point. It's still plenty rideable, but the increase in force to pull the clutch is noticeable, as is the decrease in "friction zone" travel.
There's still plenty of room on the bar to slide the MC further in (see the blue arrow), but the reservoir is contacting the larger portion of the Flexx bars and binding up, not allowing it to move any further inwards.
Are there any master cylinders out there that are spaced off the bars a bit that would allow clearance for this issue? It doesn't need to be much, probably 1/4" would be fine. I really like the AJP clutch, so that's what I'd prefer, but I could probably be talked into something else.
Thanks!
Thanks!
