Hi folks, my 2004 EC200 has what I assume is the same hydraulically actuated clutch that they all have. I had the line off while the engine was out of the frame. Now I want to bleed it and I can't get it to move any fluid. I poured DOT 4 in to the reservoir on the handlebars and with the banjo fitting on the slave loose, I pumped the lever many,many times. No fluid seems to be moving out of the reservoir. I tapped it gently with a hammer, hoping to dislodge any air bubbles that may have been causing a problem, but to no avail. What does this panel of experts recommend?
