Clutch problem again? I keep breaking the fiber plates. i sanded the basket down and it is smooth. The metal plates look good but could they cause the problem. i use moose fiber plates. what else could cause it??????????
If there is a lot fore and aft plateslop in the basket, that could cause them to break...also bad cushions, #11 on the fiche "silent block"
Filing down the ridges on the basket fingers is only a quick fix to get you thru a ride or two..IMHO...if the basket is that grooved that it needs filing, the basket is toast.
