Hi, I have a leak from behind the piston in the clutch slave cylinder, I can't see how to get it out of it's 'seat'.
I can't use the lever as there is no fluid pressure, even after bleeding.
Anyone know?
Cheers
its a 2010 ec250 2t 6 days model.
Cover the piston with a rag & SLOWLY blow air into the fitting where line hooks up. It will push the piston out. Careful not to blow the piston across the room though (thus the rag & slow fill with air)
