Here are my notes from the earlier bikes. They include some cross over info too.
Counter shaft bearing 6305C3 (Grainger # 4ZXJ1)
Countershaft Seal 30x40x7
Clutch bearing 6205Zc3E
Trans shafts 6203c3 (Grainger # 4zxe8)
98-02 Crank 63/28c3 or 63/28 maybe All Balls Part Number: 24-1112
Ignition crank roller Bearing, NJ206ET-C3 or KTM 50330082000 which has higher c3/4 tolerance
Note that some engines (250 and 300) went to roller bearing on the ignition side. The 2001 Xc250 had the roller bearing but the 2004 200 had two ball bearings.
Same bearing as the Honda CR250 1990-2008, Honda CR500 1989-2002, Kawasaki KX250 1993-2008, Kawasaki KX500 1993-3005, Suzuki RM250 1999-2007, Yamaha YZ250 1989-2013
Someone tried this in a 07 300 -NJ206 ET -C3 (LHS) and 63/28-c3 (RHS)
question is are the Crank seals the same as the 01 02 models - ie kok 20x35x6 -viton (LHS) and kok 38x52x7 -viton (RHS)
1 x SMALL END BEARING INA KBK 18x22x22
1 x LHS CRANK BEARING SKF NJ206ECP - C3 (TPZ- this should be the ET not ECP)
1 x RHS CRANK BEARING SKF 63/28 - C3
1 x COUNTERSHAFT BEARING SKF 6305 - C3
1 x LHS CRANK SEAL KOK 20x35x6 - VITON ktm 47030076100 04-14 105 85 65
1 x RHS CRANK SEAL KOK 38x52x7 - VITON ktm 0760385273 94-14 250 300
1 x COUNTERSHAFT SEAL 30x40x7 Suzuki 09283-30061
Shift Shaft Seal 12x22x7
KICKSTART shaft SEAL 20X30X7
