I have a couple of issues that I need to find answers to. First off, I have a 2005 ec250, according to the shop I took it to, they said the compression measured 110 and that was low. I was wondering what it should be.
Second, if the compression is low I would need rings. Should I replace other parts while I’m in there? I’ve been shopping on ebay and gofasters and found two kits. One is a complete vertex kit that includes pistons etc. Described below from ebay:
COMPLETE TOP END OVERHAUL KIT FOR GASGAS EC,XC,DE,SM 250 .INCLUDES VERTEX "A" PISTON WITH RINGS ,PIN & CIRCLIPS .HEAD O-RINGS ,BASE GASKET ,BOTH POWER VALVE GASKETS ,WATER OUTLET GASKET AND WRIST PIN BEARING
The other one is from the Gofasters and it is a Wiseco.
The last question I have is – If I’m doing the rings, do I need to have the cylinder honed or sleeved or what? Obviously – I haven’t done this before but it will be my winter project. Thanks in advance.
