GMP
Active member
OK guys, I've been around these bikes and others for a long time and this is a first for me.
Quarry Run in Hancock Sunday, lots of big hills, mud, what I would call high intermittant engine loading. Bike ran great most of the day, pulled the hills clean and kept ahead of a friends KTM 300. Jetting is good, no issues. After about 85 miles bike starts to rattle and surge a bit when throttle chopped, like its going lean. I think fuel so I check, crack tank cap for vent, tweak air screw, all to no avail. Now I think maybe clogged pilot but odd because of filter I added, or maybe bad gas at last stop(station). Hit the road and head back to the truck, bike seems hot but runs OK on the throttle, and will settle into an idle after surging a bit. Shut it down, get changed, let it cool, and check coolant. Almost NONE!
WTF??
Never saw/smelled any coolant steam, neither did friends close behind me. A KTM250 in our group boiled and the cloud was obvious as you would expect. Now I'm concerned that the new motor is damaged, being run 5 - 10 miles with no coolant. Scrubbed it down good last night. Compression tests like it did after break in, 180 PSI, good! Pull the top end, looks like new! Lots of red Amsoil over everything and no evidence of coolant in the crankcase. Inner head oring just a little sticky and distorted from heat but not bad. Trans oil fine, no coolant. No evidence of all the coolant blowing out the line on the front of the cylinder, like you can usually see, as glycol leaves a residue. Just dry here like nothing happened. So, this leaves an external leak somewhere. Everything looks fine on the rads and hoses, plus the rads are well protected. Now I'm thinking maybe the cap is bad and just leaked slow all day rather than dumped alot at once. Has anyone ever seen this? I'm going to pressure test everything, and send the head to Ron while its off. I don't want to put this together and ride it without an answer.
