Cooling fan on XC300
cladoo
I have PTech rad guards/frames on my 2019 XC300 and they have the mounting holes for a SPAL fan. I bought a fan and was wondering if anyone has done this on their bike. The rad hose and thermostat seems to be in the way and would be rubbing on the fan. I'm not sure what to do. I'm only thinking I need the fan as last fall a couple of times my bike boiled after a climb and my old 2010 300 Nambotin never did!
I got the fan on,removed the thermostat and put the thermoswitch holder in place. I had to cut and wrangle the hose to fit. But it is rubbing against the fan housing. Do I have to worry about it rubbing and wearing a hole in the hose? I had to put a plug in place of the switch because they forgot to send the switch!
I did shorten the hose from the engine and put a piece of pvc pipe over the hose to protect it.
So I never did get the thermo switch from the guy I bought the fan kit from. So I ordered one off of fleabay and installed it. The spec for this switch is supposed to be 85c(185f) on but it turns on at around 75c(167f) and doesn't shut off until around 60c(140f)! The switch that was supposed to come with the kit specs at 100c(212f) on and 90c off. I can't seem to find a switch anywhere. I think it is coming on too soon and staying on too long. I am trying to get the right switch from the guy but he is very difficult to get in contact with. Solutions? or should I not worry?
I don't run a thermostat and find that the engine stays around 130F all the time. Might be a bit low but I don't worry about it. Provides lots of cooling headroom if needed.
I took out the thermostat also as I needed room for the switch manifold and the temperature sensor on my Voyager.
I had a fan on my 2010. the bike didn't boil much without the fan, and once the fan was fitted it never boiled, but it would boil much quicker if i didn't turn on the fan because the fan blocks air flow (when it is off obviously)
I had similar issues with the temp switch and eventually just got a manual switch. Turned it on when things got tight and off again when i got to the top and got airflow again - Easy as!
